home Parts Photos search menu
search 250R
The ATC 250R
The Honda 250R App
valmkt.com is reader-supported. When you buy through links marked with $$, we may earn a commission.
250R Service Manual
We have posted some exerpts from the 1981, 1982, 1983, and 1984 Honda 250R service manual here. Hopefully we have covered much of the common questions typically found in a service manual.
There are some diagrams here and more information to follow as I build the page. I have also posted some info on the 1985-1986 models here.
81, 82, 83, 84 250R service manual
General Maintenance
This info will be posted soon... for now please use the 3'um for 250R maintenance questions.
Fuel System
This info will be posted soon... for now please use the 3'um for 250R fuel system questions.
Engine
This info will be posted soon... for now please use the 3'um for 250R engine questions.
AC Generator
This info will be posted soon... for now please use the 3'um for 250R generator questions.
Clutch
This info will be posted soon... for now please use the 3'um for 250R clutch questions.
Shifter, Shift Linkage
This info will be posted soon... for now please use the 3'um for 250R shifter questions.
Kick Starter, Transmission, Crankshaft
This info will be posted soon... for now please use the 3'um for 250R transmission questions.
Front Wheel, Suspension, Steering
This info will be posted soon... for now please use the 3'um for 250R front wheel and steering questions.
Front Brake
This info will be posted soon... for now please use the 3'um for 250R front brake questions.
Rear Wheel, Drive, Brake
This info will be posted soon... for now please use the 3'um for 250R rear wheel and brake questions.
Suspension
This info will be posted soon... for now please use the 3'um for 250R suspension questions.
Rear Fender, Exhaust Pipe
This info will be posted soon... for now please use the 3'um for 250R exhaust and fender questions.
Electrical System
This info will be posted soon... for now please use the 3'um for 250R electrical system questions.
Troubleshooting Guide
This info will be posted soon... for now please use the 3'um for 250R troubleshooting questions.
As a footnote, the ATC250R has ridden into the sunset from a manufacturers point of view, however, these off-road vehicles still have a quite a cult following. Whether you are planning to ride this weekend, or get started on a frame-up restoration, the electrical system is a critical component to the 250R.
I have also listed some 3 wheeler parts here. These are some of the more popular suppliers and may be worth a look.
And use the buttons below to share the glory of the legendary 250R... Keep on Ridin'...
Elsewhere in Triking
