home Parts Photos search menu
search 250R
The ATC 250R
The Honda 250R App
valmkt.com is reader-supported. When you buy through links marked with $$, we may earn a commission.
ATC250R Twist Throttles
ATC250R twist throttles probably haven't the biggest concern regarding three wheeled ATC safety, but they do enter the arena regarding their use.
dangerous twist throttle injuriesPutting some thought into the twist throttle leaves most off-road ATC enthusiasts with questions.
With a twist throttle, most commonly use on motorcycles, rough terrain can cause your body to rotate the grip and accelerate unintentionally. If the rider hits an unexpected bump while hanging on tightly, he/she may accidentally give more juice then they would like.
The stock Honda thumb throttle reduces that risk. Let's look more closely at ATC250R twist throttles and the feasibility of their use.
Thumb or Twist?
The thumb or twist question still rings out at the ATV dealers from time to time. Honda ATC's, particularly the ATC250R, were designed more like utility/recreation/performance machines than motorcycles. Honda engineers adapted controls that worked better when the rider is standing, bouncing around, or steering agressively at low speeds.
is twist or thumb throttle saferThumb throttles are easier to operate when the rider is wearing thick gloves or has dirty/muddy hands; this is a factor for trail and farm use. Riding gloves typically worn for racing also became an issue escpecially if the rider is on a rough dirt track.
On three wheelers, the rider often had to shift their body weight somewhat aggressively to keep the machine balanced in turns and on imperfect terrain. A thumb throttle allows for a firmer grip on the handlebars while still controlling acceleration.
Honda popularized the setup on their three wheel ATC's including of course, the ATC 250R, and this design later would become the standard across most ATV's from the major players in the industry. This overall acceptance began to silence the thumb or twist question.
But is the Twist Throttle Still Better?
A twist throttle, which is commonly used on motorcycles, has its own set of pros and cons. There are clearly some advantages including control with precision, ergonomics and rider comfort, and the ability to take quick action. So fans of this design insist that the twist throttle is still better.
ATC250R throttle accidentA twist throttle can allow for precise control of the ATC/ATV speed and acceleration. The throttle response is directly proportional to the amount the throttle grip is twisted, providing smooth and fine-tuned control.
Many riders find twist throttles to be ergonomically comfortable and intuitive to use. The twisting motion can be more natural and less fatiguing for the hand and wrist compared to other throttle types.
The twisting motion of a twist throttle allows for quick and immediate throttle response and this can be an advantage in situations that require rapid acceleration or maneuvering. With a twist throttle, ATC riders can vary their grip and hand position on the handlebar, reducing the risk of prolonged hand fatigue and discomfort.
Yet, with all these benfits, the safety issue remains when the terrain becomes less than perfect, or when the rider begins to shift his or her weight during aggressive turns.
Convert an ATC250R to a Twist Throttle
To convert, or not to convert. that is the question... How many riders actually convert to the twist? Well, there's no reliable industry statistic for this, and ATV manufacturers have no way of acquiring and publishing conversion rates. But based on aftermarket sales, racing culture, and online rider discussion, the percentage of ATC's and ATV's in general to have converted to twist throttles appears to be very small.
Honda ATC modern historyThe aftermarket for conversion kits are widely available, but it's still a niche modification rather than a mainstream trend since the thumb throttle is such an effective design.
After all the research, what appears to be obvious, is that an ATC250R twist throttle conversion is not the best way to improve an already impressive three wheeler.
Are Twist Throttles Dangerous on the ATC250R?
There's actually strong evidence that twist throttles can increase risk on a Honda three wheeler like the ATC250R, but using the word "dangerous" to describe this throttle configuration depends on how you "twist" it. (no pun intended). Twist throttles can be somewhat dangerous on an ATC250R due to sudden throttle input on such a short wheel-based vehicle and can contribute to wheelies, and that is a fact. Sudden acceleration also causes unwanted fishtailing, and worst case secnarios are the rollover incidents.
There is evidence that the danger is more from a combination of the unstable three-wheeler chassis coupled with aggressive rider movement. If you add rough terrain into the mix you have a recipe for twist throttle danger.
So for an average rider, particularly a beginner, the thumb throttle is generally considered safer on an ATC250R because it reduces unintended acceleration during rough riding or panic moments.
The ATC250R is a handful regardless of throttle style, so be on the alert whenever you are in command of this legendary ATC, regardless of the right hand fuel delivery controller... and Keep on Ridin'...
Elsewhere in Triking
